Fleetwood_Coupl's avatar
Nov 08, 2015
Dish network with Trac vision roof mouted dish.
Not sure the best place to ask this but here goes. I am about to pull my hair out trying to get this receiver to work with the roof mounted Trac vision dish. At first I can get it locked on sat 119 run a check switch and get it to download the guide. But if I move it to sat 110 it will not pick up those stations without running another check switch test which in turns removes the previous one. So it takes about 15 minutes to change from one sat programming to the other. Customer service is not very helpful. Thier one suggestion was to let amother rver with a actual dish hook to my receiver and do a check switch test. That worked and I have all 3 sat listed now but when I hpoked it back up and locked on to 11o it goes to check signal and never finishes or makes it to download the guide and stops and says total signal loss. No obstructions and I haven't moved the coach. Anhone know a work around?
Thanks
Eric
  • chuckftboy wrote:
    I had a KVH on a 09' Pace Arrow that I sold 3 weeks ago. I had no issues with it and when I pulled in 119, I also had 110. The KVH had 2 coax connections at the dome. One was the master and one was the slave. Mine had the master ran to the front tv and slave to the rear tv. If I scanned from the front receiver, it brought in both satellites and I could switch back and forth through all channels
    If I scanned from the bedroom receiver which was connected to coax 2, I could only connect to one satellite and would have to re-scan to get the other. If you go to the roof and switch the 2 coax connections, I think you problem may be resolved.
    None of this has to do with the recent changes by Dish which has caused issues with dome systems from King Dome and KVH. The Dish changes have caused a real problem and it can either be fixed by a software update or (depending upon the model) has rendered your dome useless.
  • I had a KVH on a 09' Pace Arrow that I sold 3 weeks ago. I had no issues with it and when I pulled in 119, I also had 110. The KVH had 2 coax connections at the dome. One was the master and one was the slave. Mine had the master ran to the front tv and slave to the rear tv. If I scanned from the front receiver, it brought in both satellites and I could switch back and forth through all channels
  • First, that suggestion from KHV will not work...ever. It will be a different check switch type and of no value to a dome user.
    Second, Dish changed their broadcast signal rendering many dome style antennas useless without new software. You need to talk to KVH to see if your antenna can be re-programmed or whether the Dish changes has rendered your dome a brick.
