Bill.Satellite wrote:
The only cons would be the same with any dome system. You can only watch 2 different channels on 2 different receivers if the channels are both being broadcast on the same satellite (Dish uses 3 satellites). Winegard also sells antennas meant specifically for Dish so you should compare. I should also mention that the other possible con is that this antenna is a Dish only antenna whereas you could also buy an antenna that would work with Dish or DirecTV in case you changed your mind in the future.
thanks I think I have found that the Winegard PA-6002 Pathway X2 Satellite TV Antenna is best one for my wants
Iam aware that's its Dish only they seem to have good coverage lots of channels and priced competitively
