Ivylog's avatar
Ivylog
Explorer III
Jan 24, 2017
DIY install of a LED TV.
Helped my brother remove the boat anchor crt TV from his MH. Went to Sams and found a marked down 39" Vizio smart TV for $172 which would fit between the cabinets on either side of the box for the old one. The new one had feet at either end of the screen so pivoting from the bottom to get to the new storage area looked promising.
Removed the two legs and bought two 2" strap hinges that with some wooden shims to make them fit tightly would serve as the pivots to lay the TV down... was able to use the same screws to hold them that held the feet in. Fastened the other ends to the alum cross brace at the bottom of the box and put a 10lb snap catch at the top to hold the TV closed/upright.
Will post pictures later.
One of the two feet that the TV sits on.
Was able to use the hole at the end of hinge and had to drill one hole in the center of the hinge for the second screw than used to hold the foot in.
Used part of the strap that held the crt boat anchor in to hold the TV level when open. Need to buy some plastic storage boxes of the correct size for the new storage area that is 18" deep and 30" wide.
Was able to use the wooden frame from around the face of the box to fill in the hole at the top.
  • Ivylog's avatar
    Ivylog
    Explorer III
    I doubt your Knight bounces all that much and the new TV does not weigh over 15lbs and none of that weight is on the latch...all on the two new hinges at the bottom. Because the floor of the box slopes slightly downward we installed the strap that was around the old TV so it will keep items that he puts in the box from pushing on the back of the TV while bouncing down the road. Doubt the massive acceleration of a DP will put 10lbs of force on the latch at the top of the TV... would take a total of 20lbs against the back of the TV.
  • "10lb snap catch at the top to hold the TV closed/upright."
    Maybe I am missing something but that doesn't sound strong enough. I'd put something up to lock it in position bouncing down the road.
  • Can't picture that in my head. Looking forward to the pictures of the installation.
