fourmat wrote:
This is not a job for beginners you will have thousands of dollars in paint and materials for a job done correctly You also will need a pressure fed paint application so you can mix and spray several gallons of paint. Enclosed building what type of ventallation will you use? The devil is in the details and doing this alone you will have weeks of prep work, masking,sanding and primeing. Then everything has to be perfectly clean dry and tacked I was in the auto body biz for years and would not tackle it.
And that is why you do it in sections so that you do not need to mix and spray gallons of paint and have weeks of prep work at one time. RV's have many places where you can have a paint break, both vertically and horizontally. Painting one section at a time will still allow you to use your coach between painting periods and also allow you to purchase exactly how much paint you need, as you need it.
