rk911
Dec 10, 2017Explorer
Retired VSP wrote:
I tow a 2006 Honda Accord....been using a brake buddy but since it's not a heavy vehicle I don't want to use the brake buddy. Most of my travel is level with some slight hills. Used to do the 11,000 foot mountains but not now. Any thoughts on this. Thanks.
if you'll check your MH's documentation or check with the mfg. I bet you'll find that the brakes on your MH are rated for the GVWR of the MH and not the GCWR. that means that if your actual MH weight plus the actual towed weight of the accord is less than the GVWR of the MH you might be able to get away with it. but IMO you should continue to use your brake buddy cuz it's one of those things I'd rather have and not need vs need but not have. since you already own one and assuming it's in working condition then all you're really out is setup and take down time.
