dougrainer
Aug 01, 2015Nomad
Ductape wrote:
Nonsense. Mine does not leak. Any tech worth his pay can find and fix the leak in the a/c.
Leak was a wrong choice of words. I should have stated that when the engine goes to zero vacuum, the demand on the vacuum from the After market AC systems uses up the small amount of vacuum in a few minutes. I state this from working on Dash AC motorhome systems for 36 years and after numerous various manufacturers attempting to replace actuators/hoses/vacuum reservoirs, they ALL stated, this type problem is NORMAL. If you want to eliminate the problem, you install the 12 volt vacuum pump on Gasoline Class A chassis. Even Diesel chassis's, you will get customers that come in and complain about this buzzing noise they hear while in transit for a few seconds all the time. That noise is the 12 volt vacuum pump replacing the used/lost vacuum. It runs for about 1 minute after the RV has not been driven to vacuum up the system and then runs a few seconds whenever the vacuum has dropped down. BUT, IT IS A NORMAL PROBLEM. Especially on Ford Chassis's. For the cost to use as mityvac and troublshoot the actuators and hoses to find a possible leak at a shop is way more than just purchasing a 12 volt vacuum pump and installing and eliminating the problem. Doug
38,763 PostsLatest Activity: Dec 05, 2025
