obiwancanoli
Nov 03, 2021Explorer
wa8yxm wrote:
I will say YES a small one (100-200 watt inverter type precise size depends on your converter)
WHY... A Generac 1000 (True 1000 watt "Traditional" generator enclosed about as loud as a Honda EU-2000i at half load) will power a Progressive Dynamics 9180 (mine was a plug in module so I could feed JUST the converter) for a good 6-8 hours on a small tank of fuel.. The ONAN sucks between 3 and 8 gallons doing that. Though the noise is not much higher
But I liked being able to use the small one to top off the battery when needed instead of the big Onan.
Also,. from time to time I needed that thousand watts remote from the RV.. I have. for example an electric chain saw.
In fact, this was one reason I was considering it... When I boondock, I search the area for downed wood I can use for a campfire, and usually, that wood would have to be cut with a saw. Absent a battery operated model, unless I were close enough to the coach to plug in, a small portable generator would come in handy... but if that's the only reason to have it along, methinks a quality battery operated reciprocating saw (or something similar) would be perfectly fine...
38,767 PostsLatest Activity: Sep 19, 2016
