rjstractor
Nov 06, 2021Nomad
theoldwizard1 wrote:obiwancanoli wrote:
having recently used a Honda 2K to charge my house batteries (don't ask, long story, not relevant), the small generator was ruined due to the high demands of the coach charging system.
Sadly, you learned the hard way ! NEVER use the 12V outlet of a portable generator !! I don't know why they are even on most generators.
No idea how it was inferred that the 12V outlet was used, since nothing the OP wrote indicated that. In fact, nothing that the OP stated even indicates that the generator problem was directly due to using it to charge the coach batteries using the onboard charger. Chances are the generator is not ruined at all. First thing I would check is oil level. Those little Hondas have tiny crankcases- oil capacity is less than half a quart. But like any small gas engine, they use oil, and the harder the engine works the more oil it uses. It doesn't take much of a drop in oil level to trigger the generator's low oil shutoff, which will do exactly as the OP describes- the generator will start and run for a second or two, then die.
38,782 PostsLatest Activity: Sep 02, 2026
