Well Gang,
Our brake lights DO COME ON with the use and, activation of the exhaust brake. For safety sake, I agree with that operation. The primary reason is, if you're slowing down, manually, that is, by the use of any braking mechanism, how in the world is anyone following you going to know that you're slowing down? Even if traffic is light or, the sun is in particular position, or any set of circumstances, and a driver is not at his or her best that's following you, and your exhaust or, Jake brake is doing it's job, than before you and, either him or her, realize it, you're slowing down and, he or she, has either ran into you or, at the very least possibly come real close to doing so.
Most of the time, I agree with Bret Wolf on most matters but, in this case, it to me, really doesn't matter if the grade 14 miles long, if some one following me sees brake lights and, again even if they're on for an extended period of time, at least they're warned and can take action as they see fit to avoid a possible rear-end collision. Besides, I've been on some long grades in which the E-brake as been activated for extended periods of time and, I give it a "break" every now and then by stabbing on the brakes with enough pressure and, slow enough to de-activate the exhaust brake for even a just a few seconds at a time.
Then, it eventually is triggered again. If conditions warrant it, I might use the flashers to warn fast, rear approaching drivers that I am GOING SLOWER than the normal flow of traffic.
It's a matter of preference and or, just what one regards as "safety" measures.
Scott
