lacofdfireman's avatar
Aug 07, 2015
Does furnace need propane to work?
So my neighbors are using our Motorhome for a family trip and called us last night and said they can't keep the pilot light for the propane, water heater lit. I was thinking at full hookups I was under the impression that the 50amp service would run the furnace without the use of propane? Is this right or wrong? My coach is a 07 Georgetown 350DS.
  • WRONG!
    Furnace uses propane as a heat source and 12VDC as ignition and control source.
    Water heater could be gas only or gas/electric depending on make and model. But it also will require 12VDC to operate.
