SSki
Jun 15, 2013Explorer
Livingthedream11 wrote:SSki wrote:
Yes, clean the gas burner. We have a Dometic side by side and experienced exactly what you are describing on a trip. Cleaned the burner and it has worked fine ever since.
Is this easy to do? Usually have everything serviced by professionals. But would like to attempt on my own.
Yes, it is easy. I just used a brush, ran it through the burner tube and cleaned it out. A bunch of scale came out. Then I put it back together and worked. I was out in the middle of no where and didn't have a proper burner cleaning brush, so I used an old toothbrush that I zip tied to a screw driver to make the handle longer so I could reach in there. You can buy an actual brush designed just for this though, I think I saw them at Camping World.
Good Luck
38,782 PostsLatest Activity: Sep 10, 2026
