tlaferriere's avatar
tlaferriere
Domestic water pump quit working
hello all, my first post. Waterpump has recently decided to stop working.
1999 Monaco Windsor 36'
3 Momentary switches on rig to turn on waterpump, none work. I do hear a "clicking" in the main water pump switch if any of the other switches are engaged so they all seem to still "talk".
Fuse labeled waterpump tested and working.
There are no inline fuses I can find.
Water pump works fine when directly powered via battery.
I hear a relay may be the problem, but dont see one.
Thoughts?
Thank you,
Tom
  • Two things: Listen to the above two posters. They are very knowledgeable. and be sure to come back and post your solution once you've got it fixed. That helps everyone on the forum. Welcome to the forum also. You'll find lots of helpful people on here....Dennis
  • Ivylog's avatar
    Ivylog
    Explorer III
    The controller/latching relay located as ^^^^ may have a fuse and/or a relay near it. The relay is a fairly common type reminding me I need to get a spare one.
