dougrainer
May 16, 2014Nomad
teddyu wrote:
On our 2852 unit, the thermistor is located in the right rear top corner. We clip it to the first fin, about half way between top and bottom. If we want it colder, we slide it towards the bottom. It should stay clipped to a fin no matter what. Hope this helps. JM2ยข...
Correct. The way the OP's is installed will have the refer running full throttle cooling. Sliding up and down the fin only changes the temp 3 to 4 degrees. Doug
38,776 PostsLatest Activity: May 15, 2026
