Old-Biscuit
May 16, 2014Explorer III
Thermistor Location
Tip (bulb end) of thermistor should just protrude from top of plastic clip
Clip should be attached to farthest right hand fin mid position
For those that do not have a temp adjustment on upper panel (preset temp control)
*Moving clip UP will result in 'cooler' temp in food section compartment
*Moving clip DOWN will result in 'warmer' temp in food section compartment
NOTE: After repositioning clip...wait 24 hrs. to check temp
Movement of clip can result in 6*F-8*F change in temp
38,776 PostsLatest Activity: May 15, 2026
