dougrainer
Feb 29, 2016Nomad
The freezer has no temp sensor. The temp sensor in your model is the Evap fin sensor.; The evap fins will be 10 degrees COLDER than the actual temp, so at 40 degrees the refer is within spec. The ideal would be 23 to 27 degree readout which add 10 degrees to that reading. Are you at MAX cold (5)? Doug
