chuckftboy
Feb 29, 2016Explorer
If you want to check the accuracy of your thermometer, fill a glass with crushed ice and water then put your thermometer in it. If it is calibrated correctly, it will read exactly 32 degrees. This is the temperature that water freezes and ice melts, plus or minus latent heat that the thermometer can't read.
