With Dometic CCC tstats, you CANNOT replace with another brand Tstat. ONLY if you run new wiring from each Zone to the roof AC units and then replace the roof AC unit control box with a NON-digital Dometic control box. You would install a Analog Dometic control box in each unit. After 20 years of the Dometic CCC system, I NEVER get complaints from customers about inaccuracy unless the OEM has not installed the system correctly. THAT happens a lot. Once the customer has a specific complaint and they want to pay for the repair, I can fix the problem. But to state, they are junk, just shows you really do not know what you are talking about. Doug
