dougrainer
Aug 14, 2015Nomad
JimM68 wrote:
Road day today, covered a whole 140 miles in 4 hours with 1 short and 1 long stop.
2 and 33 degrees when we unplugged at 11am (fridge switched to gas) and hit the road.
6 and 43 when we parked and plugged back in at 3 (fridge switched back to electric).
Again, I removed the lower vent cover and waited. Now at 9, it is 6 and 37.
I'll check the heaters
And I need to find a couplle days sitting still, switch to gas, and see if it cools.
It sure does semm my problem is related to moving...
If related to moving, then the 2 drain tubes are probably the reason. BLOCK them OFF next time you travel and see if the refer maintains its temp. Has the Cooling unit ever been replaced? Doug
