holstein13's avatar
holstein13
Explorer II
Aug 07, 2015
Don't fight the bulge
At Spartan class this week, I learned a ton of new and interesting things, but one of the most useful is that the bulge in your tires are part of your suspension.
OK, OK, I know that hundreds of you have been saying that your tires are an important part of your suspension, but I've never heard anyone specifically say that the bulge constitutes an important part. Of course this makes perfect sense. After all, did you know that your tire width is measured at the outside of the bulge:
In class, we weighed our coaches on each corner and then looked up the charts to determine the exact PSI to set our tires. Mine was 10 pounds over inflated on the steer tires and 20 pounds over inflated on the tags so I let out air to get them to the proper pressure.
After a four hour drive, I'm happy to report that it made a HUGE difference in ride comfort. The tire and brake instructor explained that the bulge takes the first shocks and the suspension is designed to work with the tire bulge to absorb and react to bumps and vibrations.
If you needed another motivation to weigh your coach, I can only encourage you to do so and set those pressures properly. In addition to a better ride, you'll get better traction and braking as well.
