moose888's avatar
moose888
Door seal FIXED
Fixed my rubber door seal that was pinched between frame and door. I used 1 1/2 inch foam pipe insulation cut in half and put between the door seal and frame to push out the seal when the door was closed. I think the heat over the last couple of weeks helped put the rubber seal back into it's original shape.
Hope this helps anyone who may have this issue with a door seal.
