When purchasing a Class A DP should consideration be given to the hosepower or are all Class A powered sufficiently. Some older ones have the 260 HP Cummins engine and was wondering if this is adequat...
I don't believe you would be happy with the torque output of that small motor. It will get you to the top of the hill just understand that patience truly is a virtue and don't ever back off the throttle going up the hill because you will be creeping. I love my 525hp CAT with 1650 ft lbs of torque.....
