Bluedog
Nov 15, 2013Explorer
DP Horsepower
When purchasing a Class A DP should consideration be given to the hosepower or are all Class A powered sufficiently. Some older ones have the 260 HP Cummins engine and was wondering if this is adequat...
Bluedog wrote:I don't know the weight of the DP or what year V-10 or the weight of it. But if the DP weights 30k lbs and your V-10 weights 15k lbs with the 362 Hp eng I think you will be disappointed with the performance of the DP on a long hill climb.
When purchasing a Class A DP should consideration be given to the hosepower or are all Class A powered sufficiently. Some older ones have the 260 HP Cummins engine and was wondering if this is adequate.
I presently have a Ford V10 and travel trailer which leaves a lot to be desired even on freeway grades and don't want to be disappointed.
