Bluedog
Nov 15, 2013Explorer
DP Horsepower
When purchasing a Class A DP should consideration be given to the hosepower or are all Class A powered sufficiently. Some older ones have the 260 HP Cummins engine and was wondering if this is adequat...
DanTheRVMan wrote:Mr.Mark wrote:
As I've mentioned before in the past, we go slow up steep inclines. I can pass some truckers but most motorhomes pass us. We have the 425 hp Cummins with 1,200 lbs. ft. of torque. We weight just a hair over 40,000 lbs.
I just let the cruise take care of the speed but if I get a running start, I can pass a lot of vehicles. One problem is, if we get caught behind a very slow truck, it's hard to pick up speed to get around them while climbing the hill. I'm not trying to race up but I thought that we would go up faster.
The new coach I'm thinking about has 500 hp w/ 1,750 lb. ft. of torque and weighs over 50,000 lbs. I may be in the same situation.
MM.
http://www.prevostcommunity.com/PDF/Motor%20Home%20Fuel%20economy.pdf
weight/hp or weight/(torque x rpm)
increase weight - speed decreases
increase torque (thereby increasing HP) - speed increases
increase rpm - speed increases
increase hp - speed increases
hp is simply a mathematical substitute for torque x rpm BOTH of which increase speed up hill.
On Edit - if your coach is heavy try to enjoy the view like Mark:B
