1BryNelson wrote:
RayChez says a dp is better in a crosswind than a gasser. You are a nut. And how do you justify a statement like that!
I can tell you do not know anything between a gasoline coach and a diesel pusher. I do not want to start a big argument about which is bothered by cross winds and which is not. All I will say is test drive both on windy days and you will see that it is like day and night in the difference. You can ask anybody that has had both and they will tell you the same thing.
I used to love the floor plan of my 36'gasoline coach, but driving back from Utah going through the Virgin River gorge it was so windy and I could barely keep the coach on my side of the two lane road. Now with this 38' diesel pusher I hardly notice any wind buffing. It would have to be very strong winds to notice. I say the weight difference between the coaches. My gasoline coach weight 19K lbs, the diesel pusher weighs 39K lbs. That is a difference of 20K lbs. Plus the diesel pusher has bigger and better sway bars, airbags that adjust automatic.
