j-d
Mar 20, 2017Explorer II
I did this job on an older E350 with a 460 in it, specifically 1983. On the Driver Side, I sprayed the fasteners with penetrant daily for over a week. Then I found I could loosen all the fasteners with a 3/8" breaker bar. All eight came out.
I had my manifold re-surfaced at an automotive machine shop that had a "belt sander." This sander is a machinist's tool, and it dresses to a tolerance close that of a cylinder head re-surfacing machine. A head machine can't do an exhaust manifold because the pipe connector part interferes with getting the manifold flat on the surfacing "surface" of the machine.
An old mechanic suggested this: Use stamped steel gaskets, NOT the fiber ones. The gaskets you linked look better to me than the steel Fel-Pro's that I used. Then Kent's advice continued: Apply NeverSeez to the head, manifold, and gasket surfaces. Then, torque NEW bolts till the stampings are crushed and STOP. The lubricant, and the lower-than-spec torque, allow the manifold to expand and contract differently from the head, without shearing the gasket.
A couple years later, it needed the passenger side done, and what I found was the bolt heads were wasted away, to less than their original 9/16" size. On the older chassis, I found I could force a long extension bar between Frame and Fender Liner, then put a 13mm six-point on the extension and pound it onto the bolt heads with a hammer from the fender well. Then Voila! Epiphany! They were all nearly Loose! From there, I did the same process as driver side.
It was clear to me that the beating I gave the passenger side was far more effective than my patient spraying the driver side.
I also replaced the OEM exhaust with a Flowmaster Cat-Back exhaust kit. We had a forum member awhile ago who did a Flowmaster kit AND an aftermarket high-flow cat converter. The 1983 wasn't built with a cat, so all I needed was a piece of pipe. Flowmaster kit was 3" diameter with very smooth mandrel bends and an enormous "big block" muffler.
I've added the Flowmaster part of the story because I believe part of keeping the manifolds from warping is getting rid of as much exhaust heat as possible and that high flowing exhaust system just had to help.
I also believe we can "abuse" our manifolds by coming down off the interstate, ducking into the first gas station, and shutting down right away. Slowing down, and idling a couple minutes, helps things to cool down gradually, and hopefully, together.
38,780 PostsLatest Activity: Jul 10, 2013
