Handbasket wrote:
... the Ford C's are a DICE ROLL. Some apparently handle OK, according to their owners. Others, to a vastly varying degree, respond mildly to wildly to road irregularities, cross winds, and /or passing trucks...
IMO, your best bet if you must insist on Ford is to find a FLOOR PLAN you really like on a dealer's lot, verify TIRE PRESSURES, and take it for a long TEST DRIVE including rough roads & passing trucks. Note cab comfort on both sides. If you like the results, buy it on the spot.
x99! It's really hard to figure why some drive so much better than others. I've read and experienced enough that I can offer a few comments.
1. Alignment Matters! High Positive CASTER (at least 5-degrees) and Zero to slight Toe In. Camber relates to Caster and doesn't seem as critical.
2. Tire Pressures are a bigger matter than you might think. I can testify to that from recent experience. Bought new tires and the shop "sidewalled" them. Says MAX 80? Inflate 80! WRONG!!! Get actual weights! Our actual should be 60 front and 75 rear. 80 rear didn't matter but we could barely control the coach with 80 front!
3. Weight Distribution! If it's Tail Heavy it's usually Front Light. Again, you need Actual Weights! Ford wants at least 32% on the front axle. Some say 75% of its rating, probably works out about the same.
4. Wheelbase determines Weight Distribution! Look at a C from the side. NOT counting the Cabover portion, If the House appears "Balanced" on the Rear Axle, there will not be adequate weight on the Front Axle. And sadly, Rear Axle may be overloaded right out of the factory. Put stuff in cabinets and basement storage, it's worse.
5. (Drum Roll Please)FLOORPLAN (call it Style if you like) and NOT weight distribution sets the WHEELBASE. I've seen enough and read enough to boldly make this statement and I'll stick to it. Walkaround Rear Queen Bed, Wheel Wells. Wheel wells require the whole Bedroom to be behind the Axle so the Wheel Wells won't impinge. Then they put an Appliance, or a Shower (which is the WHY for the Dome!) over the Wheel Well. This works OK if the coach is 30-31-feet. But the RV companies want to sell 26-ft with Walkaround Queen Bed and it has to be aft of the axle. Now the Wheelbase is TOO SHORT, the House appears BALANCED on the Axle, and it Handles Poorly.
I'm confident in all this to offer it as points for consideration. That said, the Chevrolet's Double Wishbone Front Suspension is less affected by body roll than Ford's Swing Axle setup is. For that reason, adding heavy duty Sway Bars to a Ford is more likely to improve handling and tracking. Rear Track Bar will improve tracking with any Live Axle Leaf Spring vehicle.
