captron33's avatar
captron33
Driver side wiper Goes too far to the left.
Wiper blade acts like it wants to fly off the coach. Anyone have a fix for this???
  • I had a similar experience, the Drivers side Wiper actually was slapping the forward mounted Mirror .
    I tried all the suggested adjustments with little success until I discovered that the Knurled ,Tapered Driver which is on the wiper drive shaft had worn out so was slipping on the shaft.
    I was able to rebuild the "Flat side" using JB Weld ,which got Me Home . Then I ordered a few replacement Knurled Drivers from School Bus Parts on Line!
    Such a Simple fix for a frustrating problem!
  • What coach? what brand of wiper?
    If the "two arm" Dyna, there are two adjustments. One is on one of the arms where there is a standard screw in a slot that allows you to change the angle of the blade.
    The other is to move the spline (have to remove the nut) over a notch.
  • Check for play in the linkage, it could be worn out.
  • RoyB's avatar
    RoyB
    Explorer III
    If it hasn't been bent all you need to do is remove it from the gear just below the windshield and move to a different geared position...
    This will make it go lower on the windshield in the other direction position...
    It may also be someone has mounted a wiper blade on it that is too long for your model windshield...
    Roy Ken
