Looking for advise on how to drop the ceiling in my 2001 HR Endeavor. I want to replace the center lights and add individual spot lights in the front of the coach. The ceiling has 4 or 5ft sections wi...
Chances are under the strips the ceiling panels are stapled and glued in place. It would be difficult to remove a panel without damaging it to the point it could not be reused.
You may be able to run wiring through overhead cabinets and then fish wiring to a hole cut in the panel where you would like the lights.
An alternative is to use Panduit Surface Mount Raceway to run wires where you need them.
