bukhrn wrote:
One more question, then I quit, do you turn your water pump on while filling the tank? This will fill your 6 gal water heater, if you wait until you're finished filling the tank, Then turn on the pump, you're losing 6 gal from your tank. Don't bother asking how I know. :R
Without intentionally draining the water heater by turning on it's drain valve, how can one wind up with an empty water heater due to an empty main water tank ... since the water heater is AFTER the water pump and the water pump can't force water into the water heater (and out a faucet) when the water pump can't take in any water from an empty main water tank?
