4x4van wrote:
Coelacanth wrote:
Folks,
My recently acquired Holiday Rambler, Augusta, B+, 29’ has a fresh water issue.
When dry camping I can only get about two days from the single 29 gallon fresh water holding tank. It’s only the two of us and we don’t shower in the RV. There is no leak.
Our previous rig, a 34’ Itasca Suncruiser, had two large water tanks. Never an issue.
Your new RV does not have a fresh water issue; YOU have a water usage issue. Your previous 34' class A rig likely had at least 3 or even 4 times the water capacity that your new rig has (my 30' Itasca Sunrise has 84 gal). It is easy to get lazy with water conservation when you have that much on "tap".
My last rig (a class C) had 32 gal, and we (DW & I) could go 3-4 days IF we only "navy" showered on the last day, but we were also very cognizant of conserving in everything we did. Sorry, but going from a large class A to a mid-sized B+, you've got to change how you use water.
You are absolutely right.
