Dale_Traveling
Mar 08, 2017Explorer II
DrewE wrote:I'm with Drew but I also think three days will be really pushing it before the inverter shuts down due to low volts. Just remember the longer you go without recharging the long you'll need to run the generator to recharge to full capacity. Throw a solar panel or two or three,,, on the roof and if the sun light is favorable you might be able to go indefinitely.
A modern residential fridge uses somewhere in the general vicinity of 1 kWh per day, perhaps a little more. A single 6V golf cart battery store around 1.3 kWh of energy, of which around half is usable. A little rough arithmetic suggests that around three days would be a not unreasonable rough expectation. Anything more precise would require measuring the power requirements of your particular setup.
