MrWizard
Mar 08, 2017Moderator
You have 600+ amp hrs total should be able to go overnight and then some if needed
We 675 amp Hrs of AGM batteries and a residential fridge
DW goes to bed 10~10:30 pm, I tun in later
If we are full at 8 pm
We will be about 80% in the morning
We use approx 130+ amp hrs overnight, tv, pc, fridge, electric blanket on the bed
If I pushed it we could go 24 hours and reach the 50% charge level
If we did nothing but the fridge, we could go longer
You should be good for the night, but you want a full recharge the next day, with a top up before quiet hours and shut down
Guessing at a minimum 4 hour generator run then start it again for supper and run till approx 8pm
Start the evening with a full charge, should be no problem,
Skimping on the recharge causes problems
