I keep getting a DSI fault light coming on when using my waterheater. It will heat up the water just fine on electric, gas or both. I have put the switch on electric only and get the fault, I can put ...
I know the water does get very very hot. It will burn you if you are not careful. I can't find a thermostat to turn it down. I think it is an atwood. I will have to check the manual.
