bigwheelsturnin's avatar
Mar 10, 2014
dual hitch receivers/storage
okay...ive done an archive search..zero...so
we go fulltime...this year...sell whole kit kaboodle..hit the road.
we wanna put storage cage back of mh...also got a dinghy tow vehicle..any suggestions.?
hubby was gonna make his own..using the old steel straight up bike mount..with angle iron..
he may still..but if there's somethin out there already?
  • yeah...i see that..and they got an extension on one...that might hold a box..this pic is great.
    we thought about the car too..honda crv..spare on back door...geez..thanks info is great.
    Dale.Traveling wrote:
    I use a Roadmaster duel hitch receiver with a 4" drop to level the tow bar and use a bike rack. Has a higher capacity than the receiver on the coach.
    You might run into a problem if the tow bar ever contacts the rack if the angle between the coach and dingy is high such as entering a gas station, shopping center and such. I shorten the tongue of the bike rack so it was not over top of the pivot point of the tow bar. Might be better to add a hitch to the dingy and install the rack on it.
  • Mount on front of MoHo. Just add light weight reciver hitch to slide bicycle carrier into. Added benefit is the front reciever, can be used for many different things.
  • The Roadmaster pictured above has the largest load rating I have seen for these hitches. I also use this hitch for towing my toad (bottom receiver) and carrying a cargo platform (upper receiver). I can carry the cargo platform or my bike rack in the upper receiver without a problem.
    I have never noticed any interference between the rack or platform and my toad. I actually have an older tow bar (Roadmaster Stowmaster 5000) with a ball socket, and have a ball hitch in the bottom receiver.
  • I use a Roadmaster duel hitch receiver with a 4" drop to level the tow bar and use a bike rack. Has a higher capacity than the receiver on the coach.
