Guysakar's avatar
Guysakar
Dual vs Single AC units.
Hello everyone,
Concerning dual AC units in, let's say, a 34' class A, is it common to be able to only run one of the units in the main area, and just shut the door to the bedroom? Does this situation differ when they are ducted vs non ducted?
I'm worried about how much electric dual units will use staying at a park, in the summer time (90+ degrees, direct sun).
Thanks in advance for any help.
  • in our Monaco, the ducts in the ceiling are continuous.
    We often run only the front A/C during the night to keep it quieter in the bedroom, plenty of cool air comes through the ducts.
    I'd guess if you need to save money on power, turn the temp up a bit. Costs way less to hold 80 than 75, right?
    Not sure trying to isolate the bedroom is the best choice, and then what happens when you go to use it and it's 90 in there?
    It requires a lot less a/c to maintain a temp than to achieve it, especially if the nights are cool and you can leave the units off at night.
  • Our M/H is 31' and has a single ducted A/C unit. It was replaced last year with a larger unit on the roof. I can't remember the BTU's sorry.
    I live in Georgia so you can imagine how muggy and hot it is here in the summer. That one A/C unit cools the entire coach to 72 Degrees without any problem. The Bedroom stays just as cool as the front area. There are 2 ceiling ducts in the BR and I think there are 8 in the rest of the coach. My only complaint is the bathroom (closet)isn't ducted. My DW just keeps the door open a few inches and it keeps it cool enough to tolerate.
    We wanted a m/h without slides. That may be the reason why our 1 A/C unit works for us. We aren't cooling the extra space. With all the slides they offer I can see the need for 2 units.
  • If the coach in question will only support 30A service and is older, then it will be able to only run 1 at a time. If its newer and has some kind of a power management module, then it will likely be able to run both (switching). If it is ducted, then you could run 1 and force some of the air to the back (assuming that it is ducted that way). But, in a hot enviroment, I suspect that you'll be unhappy with the results (both front and back).
    We had an older 30A coach prior to what we have now and it could run only 1 AC unit when hooked to shore power (both were powered when it was running via the generator).
    We would shut the door to the bathroom during the day (which was right in front of the bedroom) and it would keep the front half cool. At night, I would switch AC units. That arrangement pretty much did not work for me as it generally took an hour or so to completely cool things and it never really kept the coach as cool as I would prefer. And, during the day the bathroom was always hot.
    So, I actually made a change to the RV and wired up a means to allow me to run the rear AC unit on a separate 20A circuit. Once I did that, it worked well. The campgrounds we went to had both a 30A and a 20A circuit (separate) that allowed this to work. Once I had that, I was happy as a clam with the temperature in the RV (my wife even complained that it got too cold).
    On a coach that supports 50A service, you can run both of them all the time.
    Regardless of what the coach has currently and if you go anywhere south in the summertime, you will want and need to run both units. We did not enjoy our trips as much when we had just 1 AC unit available.
  • I have two and when I go home I have a meter hookup since I stay for several months. The total for two months average out is less than $10 per month for both running. That is going to be different depending on where you are at and cost of utilities.
  • Common?
    You need to check to see what ducted outlets come off which AC unit. Yes, the bedroom one should only feed the bedroom, however it is possible that the duct from the bedroom unit may feed into hall or bath area.
    Some thermostats or system allows the AC unit to switch automatically from AC units. This would allow the whole rig to stay cool, yet save energy by running only one at a time.
  • unless it is a long term park and your electric usage is billed extra... RUN IT ALL !!! 50 amp service and stay cool
