dougrainer
Sep 07, 2016Nomad
sdianel wrote:
1. Try a thermostat reset. Instructions should be in the manual for the thermostat or you can find them online. I have the instructions for the Comfort 5 button model if you need them, send me a private message.
2. We have 2 AC's in our '04 Country Coach. Both AC's must be on same fan mode "Low, Med or High" (one can't be on low and the other high). Have no idea why.
3. We recently had problems with our front AC not cooling and talked to a tech. He said in hot humid weather to run the fan on high. That keeps the unit from freezing and shutting down.
4. There is a phone cord connection inside the units. Unplug and plug back in.
1. A reset will NOT fix operational problems.
2. You can set EACH AC individually.
3. The units CANNOT freeze up. They have a Freeze Thermister that prevents freezing regardless of ambient conditions. Doug
38,783 PostsLatest Activity: Sep 24, 2026
Related Content
- Feb 01, 2026Community Alumni
