retiredtravelers2013 wrote:
Thanks again for all the help guys.
Keld
Your ONLY choice is to fix yourself (not advised), or send it out to the rebuilders that offer to repair and fix. The 4 button has NOT been available for over 10 years and new ones are not available. IF you decide to upgrade, then you will have to replace BOTH the roof top AC control boards as well as the wall Tstat to the NEW 12 button programmable from Dometic. Cost is about $500 to $600 if you pay someone to do the work. Parts cost are about $250 for both boards($125 each) and about $110 for the Wall tstat. Doug
