viajanteExplorer IIFeb 26, 2015Dyna BeadsJust bought new tires and had Dyna Beads put in for balancing. I remember hearing that the beads come in a bag and it takes a while for the bag to disintegrate and release the beads. Is that correct ?...Show More
RCMAN46ExplorerFeb 27, 2015Tires that require a lot of weight to balance are probably defective.When I purchase tires I tell the tire dealer I will not accept a tire that takes more than 2 ounces to balance. That is with standard pick up size.As for the beads I have the tire dealer do the standard balance and then I add the beads. I have had good luck this way.Works very well on trailer tires as the beads takes care of the trailer drums which are not balanced like the older drums on cars and trucks were.
Related ContentDyna Beads or Centramatic Wheel BalancersUpdate-Balanceing Trailer Tires with Dyna BeadsCentermatics or Balance Beads ???Tire Balance Beads ?New bathroom sink replacement bead sealer
