- racer99ExplorerWe have used Equal beads in our last two MH's and has worked, I noticed on this last set of tires with Equal my hand wouldn't get numb even after 2-4 hrs of driving-We are very satisfied & 6 yrs from now when tires are do we will use it again-Rich
pauperspride.blogspot.com - jerseyjimExplorerA bag of beads is 10 bucks. Re-use? C'mon.......
- tatestExplorer IIInternal materials do not so much balance the wheel-tire assembly as they serve to dampen the effects of imbalance. With respect to ride and feel, this often works better than trying to balance.
- rvis2005ExplorerThis year I had the tire shop remove the beads and balance traditionally.(with weights) I like the ride so much better. Tommy
- timmacExplorer
rgatijnet1 wrote:
timmac wrote:
I did some research and found Dynabeads are only reused if the tire guy does the job correct and not spill the beads on the floor.
I can't believe that deduction took research. So what happens to any type of tire balancing method if the tire guy DOES NOT do his job correctly? No product will offset a poor tire installer.
Was reading this on other forums about reusing Dynabeads, what happens you leave the RV at a tire shop and hope the service writer tells the installer to move the beads from old tires to new tires, I see a issue here with this being forgot or just not done right. - DaveinetExplorerI am running Balance Masters, which use Mercury instead of beads. The only problem I have is that the Mercury tends to flatten out at higher speeds and looses some of their balancing properties. I doubt this would ever be a problem with any of the coaches you are referring to, especially with the larger tire sizes. (smaller tire spins faster) I will say that I had a rivering problem with my original Goodyear tires. This problem actually was corrected over time, once the Balance Masters were installed. So there are some secondary benefits.
- rgatijnet1Explorer III
wolfe10 wrote:
Would like to see in writing any tire manufacturer who recommends or even approves of beads, golf balls, etc inside the tire for balance.
I would like to see in writing any tire manufacturer that recommends Centramatic balancers.
Michelin does say this about internal balancing:
The use of internal balancing materials (such as powders, liquids, gels and/or beads) in
MICHELIN® Tires does not automatically nullify the warranty agreement covering the tires. If the material has been tested and certified by the component manufacturer as being safe for use in tires, the warranty agreement will remain in effect, provided that the tire is otherwise properly utilized and maintained. If, however, it is determined that the material adversely affected the inner liner and/or the performance of the tire, then the warranty agreement may be nullified.timmac wrote:
I can't believe that deduction took research. So what happens to any type of tire balancing method if the tire guy DOES NOT do his job correctly? No product will offset a poor tire installer. - BusskipperExplorer
timmac wrote:
OK looking to use either one of these products, my 19.5 tires have some unbalance issues, what really works best...
I know the beads are cheaper but the Centramatic's are a 1 time purchase
:C
From all my research Air soft BB's, from Wal*Mart, will work and cost less than any other product.
The only time anyone had an issue was when they did not use enough for the large out of balance tires.
Just a thought,
BOL, - timmacExplorerAs of so far the Dynabeads are used more here, I wonder if that had to do with price, less than a $100 all 6 tires, I have found a set of 4 Centramatic's for my chassis for $340.00 plus delivery.
I did some research and found Dynabeads are only reused if the tire guy does the job correct and not spill the beads on the floor. - wolfe10ExplorerFor many years, I would have the front tires spin balanced ON THE COACH and really did noting on the rears.
When I made the decision to go with Centramatics, having a permanent solution to balance on both axles just made sense.
