There are lots of options in this shorter length. I like Lazy Daze and Winnebago products. Looked ar a BF before buying my LD and found the LD had a 3 burner stove instead of 2, more room in the bed over cab, and a slicker appearance (polished aircraft aluminum vs dull fiberglass). Happy with used LD. Next RV is going to be new. Any RV 10 years + will require a lot of maintenance, it is inevitable when buying used. Still less risk though, in my opinion. New is big bucks and you take a big hit on depreciation the first few years. Good luck with your search. Test and inspect everything before buying used. Bring a flashlight!
