Livies_Dad
Mar 02, 2015Explorer
Dynamax Rev
Been looking (on line) at the Rev on the Dodge Pro Master chassic. Its 24ft, Does not have dual rear wheels. Has anyone bought one and if so whats your opinion of it. At 24 ft could the single rear...
roadrunner16 wrote:
Overall I think we are going to like our REV tb. There are a few modifications I would like to see. One the waste connection is hard to get and is only 12 in. from the ground. If they could make it come out straight out and put a small door like the waste hose there we would not have to get down on our knees to connect or disconnect the hose. It should not have the last 6 in. drop. They have a washout connection so I feel the drop is not needed. If the rear tire kicks something up or you drag going out a high driveway you could brake it off or crack it. The propane line has the same problem. The skids under the long overhang are no good at all ours bent out of shape the first time we life a parking lot with a high exit. I had to add wheels to back and hope that will work better. I also had to add an extra step for the driver and passenger side, as the step is very high. Other then that I like the package very much. I know there is no such thing as the perfect RV for everyone. I like it or hate it after our summer trip We will be going here to Miss. then up the coast to Maine over to Iowa then back home.
