The biggest pet peeve for me was the noise inside the motorhome. I am fanatic about running silent. For me, the biggest culprit was the side door. This past June, before I went on vacation, I went over the inside of the motorhome with a fine tooth comb. I placed a hollow, rubber molding around all the areas of the side door that would come in contact with the screen door, the outside door, and the frame. All the noise those two were making are 100% gone. I also went over every single cabinet door and made sure the latches held the drawers in tightly, not just closed, with no movement whatsoever. I replaced the latches as necessary. I also made sure each drawer had a small felt pad. I Made sure the stove top and inside grate were secure. The microwave dish was secure, and anything that moves secured. I found out that another noise maker was the tv over the cab. It has a swivel which has a small amount of play and makes noise. I secured it to the wall plate with a bungee cord. The difference is like night and day. Although there are still some minor squeaks from the cabinetry flexing and moving, the difference is like night and day. I am also running my front tires at 72 psi, instead of 75, and the rears at 80. Everything is stock and it tracks quite well and the ride is phenomenal. My 31M Tioga now drives like a dream and is a pleasure to drive.
