It's not an "E-450" problem. It is the make and model of the MH.
I drove MANY MH's before I bought and some make/models where SO loud and handling sucked.
Not going to get into a brand name war so since you already own this MH my advice would be tire pressure, leaf springs and the Michelin's.
Lower the tire pressure in just the front. All 6 tires should NOT be the same pressure. It should be lower on the fronts.
Have a good and reputable frame shop look at your leaf springs. Metal fatigues. Everyone always want to run to aftermarket items when all what is needed is new leaf springs. I went new leaf springs and added a leaf. I couldn't believe I was driving the same MH after I had that done!
And you won't want to hear this part.......
I put all new Michelin's on my MH before heading out full time.
THE Biggest mistake I ever made.
It CHANGED the handling. Fought for months trying to pinpoint the problem surely not thinking it would be my brand new $$$tires.:R
It took an over the road truck driver to point out my problem.
The outer rib on those tires are too aggressive for a heavy MH chassis and they move back and forth giving you a tire roll front end feeling.
He took 2 fingers and easily moved that outer rib back and forth. Add the weight of the MH on that and you get the idea. Heavy semi's actually have a bald out rib to prevent tire roll.
Solution to that problem?
Take them off and replace the tires or wait years and miles for them to wear down. IMHO they need to STOP selling those tires for MH's.
