ratfink09 wrote:
Just got back from a trip to northern Vermont and much more exhausted than usual from the drive. Between the harsh ride and interior noise from every bump in the road, I could not wait to get home. Rv is a 2011 Chateau 28 ft long. I have done Hellwig sway bars and Bilstein shocks which helped handling. Just got a new set of Michelin MS2 tires under the recall. Should I be looking at replacing the stock steering damper, front end alignment, a track bar etc.? Open to suggestions!
So is your complaint now just the harsh ride and noise? No handling issues anymore? I can't see where steering damper and track bar would cut harshness and noise. Alignment always good if you haven't had it..emphasis on caster..but it won't help harshness and noise.
My suggestion right off the bat would be to study tire inflation chart by weight from Michelin and be sure nothing is overinflated...at all. When my recall replaced Michelins were installed, they were all filled to near maximum sidewall pressure. I went around and adjusted them.
