Bailey1213_'s avatar
Bailey1213_
E-450 Viberation
I have a 2000 Winibago E-450. I have a bad viberation at 40MPH. It has new tires front and rear. It does not feel like the front, I don't feel it in the steering wheel. Faster then 45MPH it seems to go away. Any ideas what to do?
  • Did they have ODB ports in 2000 ?
    If the above doesn't pan out, have somebody plug in and check for codes.
    Might be a misfire condition in the engine (long shot).
    OH.....and if you haven't had the wheels "re-torqued" since the tires were put on you should do that....NOW.
  • ^X2. Center carrier bearing usually fails before U-joints, unless those have never been greased.
