DrewE
Oct 29, 2017Explorer III
mmcclaid wrote:
No emissions testing in Indiana. Thanks for the input. I am learning more about this engine. Apparently part of what comes off the air filter box is a vacuum line that goes to a smog pump. Not sure if I can bypass this or attach it somewhere else in a modified air intake system.
If the connection is before the throttle valve (which I suspect it would be in this case), it's just the source for the air that's injected into the exhaust so the catalytic converter can properly convert. It should be fine to attach it anywhere between the air filter and the throttle body or carburetor. The purpose of having it attached to the intake system at all, of course, is for it to have clean air to pump in rather than potentially dirty air.
I suppose you could give it a little air filter of its own, perhaps such as might be used for the air intake of an air compressor (which often look on the outside something like a round lawn mower engine muffler).
