nbking's avatar
nbking
E350 Ford Chassis
In my research for a new motor home, I looked for comments on the E350 Chassis. I found some disturbing comments concerning the stability and handling of the Chassis.
I contacted Pleasureway and was advised that the Excel was built on the E350 Van Chassis and indeed did have some handling issues. It was corrected by adding spacers and with other modifications. I previously owned an Excel and that appears to be true. The only problem I had with it was scuffing on the front tires. I replaced the tires but never did find out what caused it in the first place.
Pleasureway also said the Pursuit was built on the E350 Chassis and did not have any handling issues. However, from what I read, some Class C motor homes on that chassis did experience problems.
I would like to know if anyone has first hand knowledge of the handling performance of the E350 Chassis and, if the problems were restricted to earlier years. Information from late model year owners would be very helpful.
  • We have had our 2012 Nexus Phantom 23P (24'), Class C for nearly 2 years and 23,000 miles. I have experienced Zero, Zip, Nada handling/ride issues. It is always smooth and steady and passing trucks are no problem. Yes, I feel their bow wave but so do other trucks. Driving in anything up to 35 mph winds is easy one handed steering (over 35 I just get off the road). Keep in mind that this is probably the largest (tallest - 11'4", widest - 101"), 24' C on the road today).
    Our 2011 chassis has GVWR of 11,500# (Ford increased the E-350 to 12,500# with the 2012 chassis), and we travel fully loaded at around 11,000# (as we keep adding "stuff" and I carry lots of tools and toys). :S
    Some day I will replace the original shocks, probably in another 20,000 miles or so and Bilsteins are at the top of my shopping list. I run Michelin LTX M/S 2's at 60 psi on the front and 65 on the rears. This gives me about a 20 - 25% cushion over and above the weights they are carrying/rated for and as noted the handling and ride are both excellent.
    Watch the ccc/occc ratings for any rig you are contemplating as some are woefully short on payload and will be subject to overloading. Anything on a Mercedes Sprinter chassis will be suspect. Our Nexus has 3,363# of payload and yes, we use most of it (without any problems).
    IMHO: Any new motorhome that has handling issues off the showroom floor is the wrong coach, period. Properly loaded and with the right tires/psi a new coach should perform flawlessly without any additional (costly), modifications.
    As always.... Opinions and YMMV.
    :C
