I appreciate your posts! I did think of connecting to the house power but was looking for a quick fix rather than a wire running job.
Turns out my problem doesn't exist! I thought I could only listen to the radio with the key half way to ON, which caused the heater fan to run and the seat belt alarm to bong. After looking at the Ford manual I found the accessory position is actually in the extreme anticlockwise position; in between off and on is the unfamiliar off but steering wheel not locked. I suppose that is useful for something?
Oops, the camera missed position 4: engine on, and 5: crank.
I was amazed how easy it was to get that radio out of the dash! I'm surprised it hadn't jumped out on its own. Just a gentle pry to pull the plastic surround off and then grab the radio with two fingers and slide it out.
All these wires! The manual diagram in my first post has the radio upside down so the eight speaker wires are shown on the right but they are on the left in the photo below.
The yellow wire has 12 volts all the time. This power wire comes through a choke in a little black box, presumably to reduce engine noise. The red wire is powered up when the ignition is on or in ACC and its voltage enables to radio to be turned on. It draws a full amp through the yellow wire, for the amplifiers I suppose.
