WeBeBig's avatar
WeBeBig
E350 tow hitch
Hi all, full disclosure, this isn't for an RV. Sorry, but I think this might be the best place to find help. I recently bought a 2009 Ford E350 shuttle bus to haul my crew (adoption) and need to install a tow hitch to haul our deck boat. The concern is that a regular hitch would be too far under the body. It has these extensions welded on for the bumper brackets, should I consider strengthening and bolting a hitch to those? Is there a hitch built for these that sticks out further? Is there an extended ball mount that you guys use? Any help is very much appreciated, thank you!
  • Most C motorhomes have more substantial and usually much longer frame extensions, built to a Ford specification for frame modifications. The hitch gets bolted to that, usually a standard Class III to Class V for the E-350 frame rails. Your extensions don't look to be built for carrying a hitch. I would want something bolted to the OEM frame rails in your case.
  • Thanks for the response. Are the pictures not showing up? I posted two. And I'm not using a hitch extender to haul a large deck boat.
  • Hello,
    Hitch extensions can be had for under $20 at your local parts store or amazon.com. Pics of your current setup might help in getting more responses.
    Good Luck,
