ron_dittmer
Apr 24, 2019Explorer III
bobndot wrote:Our 2007 Phoenix Cruiser 2350 on a 2007 E350 with no slide out and 40 gallons of on-board water, it measures exactly 23'-8" end to end. Pending the trip, it weighs between 11,200 and 11,480 pounds. That one trip we had gotten extremely close to the chassis limit of 11,500. I run the tires all around at 70 psi. The quality of ride is nice, though the rear end sags a bit as shown.Fully loaded for travel what would be the approximate weight of 24 ft Class C.I roll at 12,500-12,700 with approx. 50 gals of on board water.
24 ft 2018 Sunseeker on top of a Ford E450
There are two contributers to the sag.
1) Our 40 gallon fresh water tank is in the worst place possible, against the back wall. If I didn't carry water, that would help the condition a lot.
2) With all the weight in the back like that, the front axle is light. One spring rating lower (now 11500, thinking 10050) would bring the front down a bit and then our rig could go back to the stock center bushings. It's sits up so high that the alignment required offset bushings.
